Quote: Yes the scoop is molded onto the hood. (I can only hope it never becomes separated )
So, if I don;t have the spacer putting the carb flush with the bottom of the hood, then the next ideal entry would be something like
With the top sealed to the bottom of the hood and the hole in the hood matching the top of the sack?
I would set it up so the pan itself is 3/4" to 1" below the bottom of the inlet then the entry mounted to the pan, then if needed add a tube to the bottom of the entry to go onto the carb... that way there shouldnt be any turbulence in the scoop area before the turn into the entry.... I cant find a pic on my computer of the one I use and dont see it in Summit either... gonna have the wife check her laptop.... she has a pic and will post the pic
