Hello,
I am working on an engine with a 6-cylinder and a Weber 32/36.
Apparently this carb runs real badly with anything over 4PSI. My pump exceeds that and I need to regulate it down.
I have seen the low-cost dial types. I have also seen others. Reasonably priced and reliable would be good.
What type would you recommend and from where?
The vehicle is likely going for sale, so I don't need any Aeromotive stuff or anything.
Thank you, ROB
1989 Dodge Cummins & 1989 Dodge W-250
