I did it to the hot rod. You will have to modify the transmission crossmember a wee bit. I turned mine around backward for the 4 speed I dropped in. With the 727 I stuck the tranny mount in the center of the crossmember.
You will need to shorten the drive shaft.
If you have a column shift automatic the exhaust manifold will not fit around the shift brackets on the column under the hood. The column length will be the same.
If using a 4 speed the pivot mount on the frame rail will need to be moved and the linkage modified.
