If you plan on putting in new rubber, no tools are needed. Just a utility knife to cut the rubber on the outside of the window. Then remove the window and what is left of the inside rubber gasket.
'73 's are factory installed with butyl tape, they do NOT have a rubber gasket. The above mentioned brass wire is great stuff, I usually get 3 or 4 removals from one roll. Take your time, it isn't that bad. Just my
