I would like to hear an engineer tell us just how many lbs of air pressure holds a tire to the bead
I am not but I'm sure it will amaze you
Sorry but I have seen tires come off the rims when
the car was sideways ... your not going to see that
occur on mine ... as to what pressure it takes...
it s a matter of which has the greater pressure...
is it the air pressure inside it or the side loading
of the tire going sideways.
You better start screwing those front tires too
then
LAST COMMENT FOR ME ON THIS TOPIC
STAY SAFE FELLAS
