Re: 1965 318 Poly ? Rebuild or swap to LA 318?
[Re: Dennis_K]
#91382
07/21/08 11:27 AM
07/21/08 11:27 AM
Were any of the LA 318s internally balanced? We would have to use the 65 torque converter, so if the newer 318s are externally balanced, we would need to add a weight to the old converter, correct?
All the poly 318's were internally balanced, as were all LA 318's until ???? AFAIK, the late magnum 318's are also internally balanced, but I could be wrong.
