are all b-body upper & lower control arms the same? Have a spare set from a 73 charger & was wondering what else they fit.
62-72 UPPER control arms are the same.
66-72 Lower control arms are the same.
Everything changed on the suspension design in 1973, so your 73 parts only fit the 73 and up cars, NOT earlier ones.
What's the difference between 62-65 lower arms and 66-72? I just put a set of 72 lower arms on my 64 Belvedere. Other than sway bar mounts I see no difference.
Doug
