My 68 RR has 11" rears, its a power disc brake car
Then someone swapped them on there, the factory installed the wrong rear end assembly or it's not an original disc car because it's supposed to have 10" drums on the rear ....
Hey JohnRR. Are you saying that most all Dodge & Plymouth B bodies if equipped with power disc brakes would have had 10in drums?
Up until and including 1970 , not sure what they did after that .
Same for 71-4B's except this 72 wagon I just parted is the first 71-4B with disc and 11" drums I've seen.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
