i understand about the factory wires being backwards.but this has been runnin 7 years hooked up with the stock connectors.i had to shave the corners of the male end to reverse the wires.
LOL... most of us just cut the wires swap them and
use solder and shrink tubing.... because NOW you can
put it in in either direction
yeh i guess im just lazy,30 seconds with a exacto knife and slide it in,nice tight fit,plus if it fixes its self i can just turn it back over
