I'm buidling a 408(360)stroker with Edelbrock Alum. heads I have a .508 hyd cam for the motor now but was thinking about putting a .557 solid lift cam instead. The motor is going down in a 71 Demon that is basically going to be driven on the street only taken to the strip to see what it can run. Good idea or bad idea?
Thanks Brian
