Ahhh, no. That's not going to work...Think about it, how thick is the side wall alone times two, and you want to compress that into how wide a rim?
If you did still put that in there, it would be a real hazard. Its best to choose a rim with about the width of the fatest part of the slick for stability. The larger growth slicks will recomend skinnier, but I like keeping them more square for stability....
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
