it will be on the lower side of the lower control arm just outboard of the pivot point which is where the t bar goes thru the control arm. The lower control arm is shaped like a c channel and the adjuster is inside the channel.
ok i am now trying to figure out which bolt is the adjuster...anyone have a pic of one?, if not i can probably figure it out
i think i may have been mistaken on having the torsion bar out for some reason i think i was thinking of the center link
