Quote: My 452's Ross pistons had some noticeable scuffing on the skirts due to being run w/ too little oil.
How did you come to this conclusion?
my pistons/walls did also but Id say it was from the lifter trash going through! just a hunch though..pic is worse than it is.... im sure some scotch brite would clean it up! these are 4.500 diamonds and id dump em off cheap
