You can use the air grabber box with some slight mods for mounting to hood. Also the flap door and vacuum actuator are the same. The hood door will work on 71-72 Dodge but not on Plymouth. Switch, solenoid and vacuum can are different.
the 70 vacuum can is the same one as 71-72
I am fairly certain the 71-72 vacuum can has a different mounting bracket...someone else will have to confirm.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
