P5155072
Gray Iron
4.25 bore
Siamese bores
Finish honed
Standard Cam height
Uses Mopar casting #5153843
Max bore is 4.36 (but sonic checking may allow more)
Always machine any new block. This means:
Line hone
Equalize decks
Check lifter angles
Check bore taper (rehone sometimes required)
Etc ...
