Ok thank you. So it looks like the little points go through the rubber (must need to bend them over to secure) and then the clip just pushes into the hole on the cowl. I would think the best way to do this is install the clips on the cowl first and them put the rubber on and use pliers to bend the tabs over.
I agree with using the pre-installed clip version, but since you already have what you have...
give it a try...
Putting the clips on the cowl first works well...
for folding over the points, use the plastic handle end of a shorty screwdriver... at least this is the method I used in the past before the better repro's came out.
Rick
