when we did the engine we bored 30 over, went with a stock cam, used the original crank. I did nothing special tried to keep the engine original but not happy with the way it runs. It does not seem to miss or run funky on acceration and it also starts very easy. Are you guys saying I should set the timing with the vsacuum plugged at 16* BTDC
