The " - " is a dome. When you figure compression ratios, a negative is actualy the amount of cc it is displacing in the bore so to speak. Negative is a dome, positive is a flat top with reliefs. The relief would be a valve pocket/s.
Theoretical C/R because the 2295 is a 2.029 C/H piston:
# of Cyl. 8 Bore 4.3200 Stroke 3.7500 Rod Len. 6.760 Gskt Bore 4.490 Comp. Gskt .0400 Block Deck Ht. 10.7200 Top ring down 0.280 Chamb. Vol. 88.0 Dome (-) Dish -12.00 Piston / deck 0.000
Total volume 988.49 Cylinder volume 900.72 Clearance volume 87.77 Gasket volume 10.38 Top ring volume 1.39 Deck volume 0.00 Piston top land 4.275 1/2 Stroke 1.875 Comp. Ht. 2.085 Cubic Inches 439.72 Compression ratio 11.26
Now lets do it at the 2.029 ( .051 in the hole):
# of Cyl. 8 Bore 4.3200 Stroke 3.7500 Rod Len. 6.768 Gskt Bore 4.490 Comp. Gskt .0400 Block Deck Ht. 10.7200 Top ring down 0.280 Chamb. Vol. 88.0 Dome (-) Dish (+) -12.00 Piston / deck 0.051
Total volume 1000.74 Cylinder volume 900.72 Clearance volume100.02 Gasket volume 10.38 Top ring volume 1.39 Deck volume 12.25 Piston top land 4.275 1/2 Stroke 1.875 Comp. Ht. 2.026 Cubic Inches 439.72 Compression ratio 10.01
RIP Monte Smith
Your work is a reflection of yourself, autograph it with quality.
WD for Diamond Pistons,Sidewinder cylinder heads, Wiseco, K1 rods and cranks,BAM lifters, Morel lifters, Molnar Technologies, Harland Sharp, Pro Gear, Cometic, King Engine Bearings and many others.
