So I think I found the MC,A-1 Cardone.Anybody ever here of this..It looks the same,I will find out monday.Behind the brake pedal is a spring and cap with a small clip that looks like it clips around the shaft into the MC..Hope I explained this OK.Hope the pic works.it dosen't..Should I try and bend the clip a little as there is a groove in the shaft that it looks like it goes around..
