I second autoxcuda's idler arm suggestion. Do you hear a clunk when you go over a bump? That's what mine did when the idler arm was loose. Unfortunately, though, it could be several things, so I would start by seeing if you can find play in any of the parts.
It's Swifty! Swifty, you toad sucker!
