Factory Bulge Hood on this 'Cuda. I need to know if it will fit with Holley or Edelbrock/Carter carb and a stock style air cleaner???
Assuming you're talking an RB motor--no it won't, at least not with the stock air cleaner.
I too run a 440/eddyRPM/Holley carb and I have to use a pretty deep drop base to clear a 3" filter.
Stock air cleaner will sit too high.
Sorry, should have been a little clearer with my response. Mine's a "B" engine and has about 1" clearance. Makes sense that the "RB's" then would not have enough clearance.
