After refreshing the entire dash with all the stuff attached to the firewall there is one thing left, that I cannot remember how it was before disassembling:
Where does the speedometer cable run through?
I'm talking about a 1970 Challenger 440 with 4 speed MT.
The most questionable part is from the firewall to the speedometer - how does it pass the pedals? Does it run between brake and clutch pedal? On what wide of the clutch pressure rod? Where is it fixed there - is it fixed at all??
Also in the engine bay I'm not sure. Does it run between brake valve (and all the brake lines) and fender on the left side? Or goes it between the brake lines? Or on the right side of the brake stuff?
It passes the Z-bar right on the outside/ left side where the frame is, right? There is a clip to fix it to the frame - is that clip exactly under the Z-bar?
Hmm - let me extend this: Where does the (double) wire run to the transmission backup light switch? Along with the speedo-cable??
I add a pic just for fun - it does not show the questionable cable. Just to show that I found where to put the rest of things...
