if you use lacquer primer with or without sealer it will soak down shrink crack and have trouble holding a gloss it will also chip much easier. if you plan on using a catalyzed paint use a catalysed primers. the job will hold a gloss longer and be much more durable so it will look better longer.
just my
perception is 90% of reality
