I'm building a 408" stroker small block out of a 76 360 block. I have the factory heads and could have them rebuilt but I don't want to put any money into porting old heads.
I was looking at mopar performance and they have these A engine heads on their web site. Has any one used these? Do you they oil through the push rods or can I just bolt them on the block and use the factory oil system? The part number is MOPP5007950. Thanks
Also what do you think would be a good cam for this combo? (9 to 1 comp)It will be a daily driver and want it to run like a stocker just with a lot more grunt.
From the add
A" Engine Replacement Cylinder Head — 2.02" Intake, 1.625" Exhaust
Based on the Magnum R/T big-valve head design and machined to fit 318/340/360 Mopar Small Block Intake Manifolds made through 1991. Imagine the new combinations
A new iron curtain drawn across the 49th parallel
