i had an A.M. ladder bar kit with panhard bar in the '68 Dart for over 15 years. other than the top of the panhard bar bracket that is welded to the rearend making a dent in the trunk floor from bottoming out a few times because i like the car to sit low ...i had zero problems
you should go with some better shocks/springs....PM sent
