I drilled the panels for rosett type spot welds ,I added more the the factory. The AMD upper cowl and inner fender are dead on needing only minor tweeking. I plan on welding the full seam and then blend it into the lower cowl.I left the end were the hood hinges weld to unwelded for now as I will weld them in when I fit the hood to the fenders.
