2000 dodge ram 1/2 ton 4x4.Any tips/tricks to install outer seal on the right side of the front axle.I know there is a tool since the seal is inside the tube.I have the axle out and the actuator removed.I don't see a safe way of installing the seal straight.Any mcgiver tips?
