If your looking for the absolute last bit of performance gain for your car AND expenses are not a CONCERN,then look at buying a carbon fibre matrix shaft or a little cheaper aluminum shaft. Epecaiily at that length
, and when a CF self destructs, there is a lot less damage likely.
However if cost is a concern, I use and like a MW glued alum 1350 3.5" driveshaft.
Reality check, that half the population is smarter then 50% of the people and it's a constantly contested fact.
