Shady Dell built pump gas 439", small chamber ported w5's, 10.7-1, bullet solid roller 272/276 @ .725, R3 siamese, Howards ultimate rods, K1 crank, Diamond pistons, TTI's, M1 intake (temporary) with Indy intake, and 1050 Dominator to go on. Will likely see a vacuum pump in spring. 660 HP at the moment- only to go higher...
No times yet- should be a mid-low 10 sec car with traction. All I know is with E70-14's on it's a handful, still lays rubber @ 80+ mph thru 3'rd gear and sounds sweet @ 7500.
GOOD STUFF!
