I believe the springs were rapped for both quietness and to keep dirt out. Dirt between the springs is like sand paper. They probably stopped using it because of cost and dirt and water would still get in them eventually. I don't believe they are necessary. If it were a top notch resto, then I would wrap them.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
