What exactly do you want to do with the car? That .484 is a good all around cam. Sounds tough, makes good power and has decent street manners. It will work "ok" on the street with a stock converter but if you are chasing ET you will be leaving a couple of tenths at the 60 ft mark. Depends on your priorities.
Kevin
