I am in the process of mounting a dual 2-speed electric fan set up on my Dart. The fans run together on low and high.
Do I need two 4-pole relays, or can I use one 5-pole relay, to switch between low and high?
Your life is not my fault.
My life is none of your business.
Speech is free only if you agree with those in control.
