Unless that Abody weights 4500lbs it should run alot more mph if it's making 370hp. When I ran 110mph@3100lbs with a 268he cam and pistons a mile in the hole I guessed it made 325hpish,seems close. what hp would it take to run 107mph @3500lbs? I'd guess 360ish? Maybe I need a better calc.
