12 car field ? ...
LM with a Summit deal
It will be a 16 car field..they changed qualify a few years ago ...usually friday night was the fastest session..and if you made a bad run you would not get in the show..so the top 12 keep their times after friday night...the remainder start over and try to get into the last 4 slots.. this works if the weather is hotter on saturday..but if the weather is cooler..they can bump up into the field and the top 12 can still get bumped out..
this morning session in vegas should be faster then yesterdays...somewhat overcast and about 5 degrees cooler
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
