Here's
RestoRick's Web Site, but it doesn't have much info on the project. Have there been any updates?
I think this would be agreat little engine, too, and I'm keeping my eyes out for a good opportunity on a late-model one. The 2008 models got a pretty significant upgrade, and make 303hp @ 5650rpm and 330lbft @ 3950rpm. Those are almost the exact same numbers that my warm 340 make right now, and I'm sure thre would be a significant mileage increase due to smaller size and roller everything. The 4.7 will bolt up to any LA bolt pattern trans, but it's got (IIRC) an 8-bolt crank flange that is NOT the same as the old Hemi 8-bolt flange, so manual trans applications will require a custom flywheel.
Keep us posted!
Clair
