BTW...how important is it to have the butterflies partially open,as Hardcore suggests?
LABRATT, I feel it's very important. With the throttle closed can cause a restriction and produce lower than normal cranking compression readings
My personal preferance is to set the carb @ WOT when testing. Usually I'll hold it open with a wire or use the return spring to hold it FWIW.
Don't forget to return the throttle closed before you start the motor again
