Did it, just pushed the springs wthout moving perches no problem was easy.
I found out this is how my bbody 8 3/4 was installed in my 72 demon. I noticed some of the leaves on the springs were not centered with the other ones and stick out about 1/4"....just curious if yours did anything similar?
I need my pinion angle changed so I'll probably just move the perches in when I do that.
