A friend of mine needs to get a shell dipped to remove rust, then also dipped again for the primer. He is located in Ontario, near Toronto, but travels to the US often so would even consider going to the US to have this done. Would need the same place to do both dip for cleaning and dip in priming. The car has been dipped already, but was pushed aside and forgotten. So it needs to be done again, with primer this time. Thanks
