Took my alt. to autozone it was bad. Got a new one and the problem is still there. Now I'm gunna put a volt gauge in it and see if that fixes her.
One more question How do I check to see if the voltage regulator is bad. I have a voltmeter to test it with I just don't know what setting or what reading I should get.
thanks you guys are helping a lot
-matt
if your dreaming of your car then it's your dream car....
