Hey Everyone,
Well last Friday I pulled my car into the garage to put in a new stereo. I had to move the car into driveway to get something then pull it back in the garage. I get in there and go to shut the car off but no can do. The key is stuck in the run position of the column!! To kill the engine I had to pull the coil wire. Well I checked out the chilton's manual at the library and followed the directions the best I could but can't get it out. I know there are some techs on here... so I was hoping you could help. The car has a non-acustar tilt column in it. If you have any idea's please let me know.
Its an '88 Lebaron 5-spd.
- Jon
