are you running race gas now? if you need to use 108 or better race gas then the switch to E85 will be benificial for you. fuel savings and a cooler running engine alone is great. i have also seen a power increase to boot. but even if it still makes the same power as E85 the cost and temp change are worth it.
i run a 750 holley D.P. with a proform main body on my dads car and runs 11.0's with E85. your compressin will be fine.
WAXER
