Alright then. I appreciate all the great information. You know what they say, "It is what it is." I am looking at the KB362 piston which will be somewhere around 9.6:1 compression with the block decked somewhere around 0.010" This means the piston will be somewhere around 0.019" above deck.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
