I put the B&M Quicksilver in my coupe as well...seems alright so far...but the car isn't finished yet.
Q for you guys running this. When putting the shifter in 'D'...does it automatically drop down into the ratchet mode for you, or do you have to push the shifter handle down?
Mine drops down right away, but looking at the mechanism it looks like it should stay up and then require me to push it down if I want it to go into ratchet mode.
You pull it into D and it's in ratchet mode. You can't go up into park unless you are in D. Then you lift it out of the gate and move it up. I have a reverse Man valve body so I pull back on the stick to go up...you'll simply nudge it up from 1st if you want to shift manually.
