yes, and provisions are there.
on my 74 charger just did need to cut the outer skin, not even the bottom frame of the hood. ( except for bezel screws ).
I think you should find easilly the hole already there for the stud
You'll find even the wire screw provision
With a Charger born in Chrysler assembly plant in Valencia, Venezuela
