INFO: I have a 1989 Dakota 4x4 with a 4-speed auto. I had the reverse go out all of a sudden. So after disassembly the problem was that the overrunning clutch thrust bearing self-destructed. I was able to buy a A500/A518/A618 overdrive replacement kit. I am using a ATSG and factory service manual to help with my rebuild. When I disassembled the original direct clutch pack it had 6 frictions/5 steels. Now for me to get a reading that is on the overdrive piston thrust plate selection chart, I have to install 8 frictions/7 steels.
QUESTIONS: Was this an incorrect part I am installing?
Will this thing work properly?
Is this normal?
Any help will be much appreciated. I don't want to have to pay someone to rework my work.
Bill
PS I didnt have any luck looking up A500 rebuild on moparts search engine.
