Hey Guys, I have a 04 Caravan 3.8 that the water pump seal went bad last week. It leaked antifreeze on the belt and the belt started to chatter only at idle in gear. It has 92K on it so I replaced the pump and belt. But the belt still chatters. When I start it no niose, but as soon as I put it in gear the RPM,s drop a little and the niose starts. Get the RPM,s up a bit then it quits. Any ideas? This is driving me nuts!
Thanks Scott!
1966 Coronet 440 conv. original Mauve metallic, with white top and interior. 1971 360, J heads, 625 AFB, 340 cam, intake, and manifolds. With 3.23 SureGrip.
1969 Dart GT: B5 Blue, White top, 318, With A/C
