A-body spring perch centers are 43"
my A-body 8 3/4 housing is 52 1/2" wide IIRC
best to measure from flange to flange
the backset on the backing plates will vary with brake and shoe size/width
are you looking at 8 3/4 or 7 1/4-8 1/4
early A-body or 73-up
stock A-body 8 3/4 had 1 3/4" brake shoes and small wheel bolt pattern
i used moser axle with the large brake offset for B-body brakes in my 68 Dart 11x2.5
