Depending on the style of housing,use a cutting wheel on a dremel or die grinder to cut notches or slots into the remains of the socket that is stamped into the housing. AGAIN,DO NOT CUT INTO THE HOUSING!!
'68 Newport Custom Barge on a Budget!! BOAB 1973 Satellite WAGON! 318- 3 on the tree!! 2008 Chrysler 300c HEMI!
