The half ring is standard, the full ring is optional, but it blocks the speedometer some. need the build sheet to know what the car came with from the assembly line. possible the IBM car will tell you, if you can read it.
Thanks I had a 1/2 ring in it and mostly only performance options were ordered on this one . No build sheet found ( bummer)So 1/2 ring it is for now .Andy
