I think your front lines are switched left/right. The one in the rear is usually for the driver side, but I don't see how it would make a difference anyways. Also on any car i worked on, the part labeled "what's this" was for the brake light pressure switch and the thing at the back wasn't hooked to anything, but I suppose they could swap places depending on who made it?
